Try using an X10Pro PLW01 wall switch UNLESS this is an LED (i.e. Colorlogic, etc.) or SAM light. If you have a standard (incandescent) pool light you can use these parts to dim the output as well. If you have two lights, get two switches. Set the "Device Code" (black dial) to "1" for one of the lights and "2" for the other. Get a Mini-Controller (PHC01) to go with it. Make sure to change the "House Code" (red dial) onall devices to something other than the factory setting. They all have to match to work together. Install the switch(es) and plug in the controller. That's it.
For the other types of lights mentioned, use an XPFM module. It has to be wired in place of your exisiting switch and then a blank cover installed over it. It DOES NOT have dimming capability.
Relatively inexpensive remote control system.
