Results 1 to 9 of 9
Thread: slimy pool bottom and sides...high chlorine
    Jun 2013
    Maryland
    Default Re: slimy pool bottom and sides...high chlorine
    So I understand the idea that I need to correlate the chlorine with my stabilizer and not industry standards. I am just concerned about the cc and slimy pool. I thought that chlorine levels of 30 for two days would do it. Is that wrong? I need to make sure that over night the chlorine stays high and then do I just let it naturally lower? That could be a while.
    Does the low chlorine and high stabilizer make for algae growth?
    Because at the last testing the fc was in line with stabilizer but the cc was so high
    Jul 2012
    Mexico, Missouri
    Quote Originally Posted by Melbal View Post
    True. "industry standards" have been proven to be not so good here and at so many other BBB focused forums
    You need to keep the shock level -- as outlined in the best guess chart -- for as long as it takes to clear the pool.
    Three things to know when your shock is done: overnight FC loss =<1ppm; CC =<.5ppm; water clear. Keep FC high 1 additional day, then let drift down naturally. It will due to sunlight (UV) breaking down the chlorine.
    Yes. With a high CYA, most of your chlorine is bound and is quite a bit less effective for both sanitation and algae prevention.
    High CC means that the unbound chlorine is combining with stuff you don't want in your pool. CC = Combined Chlorine. Means it's killing the bad goop.
    One more thing. As long as you are at shock levels, you need to be brushing every surface in your pool, including under removable steps if you have them, and inside the light holder if present. Algae loves to hide in places like that.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    Maryland
    I am already gone for vaca so I will have to do this when I get home. I think I understand it now. Do I need to clean the cartridge filter also? With what? I have never done that. I can't vacuum to waste.... I can drain the filter to waste but cannot by pass the filter. Also.....I will
    Keep the FC up until I don't feel the slime right? (Cause the water is clear as can be Sony cant judge by that).
    One more thing.....the last test the PH was in normal range. So do I skip the muratic acid step and just do bleach or is the borax and muratic acid regimen Ben recommended to be done after the PH is in range or for something different?
    Your help is so appreciated.
    Jun 2013
    Maryland
    I have ordered the test kit. I plan to begin this regimen on Sunday. I still don't understand the muratic acid instructions . Sorry the pH is currently in range along wih alkalinity. The chlorine is really high but I am still on vaca and can't test with the new drop kit. If the PH is in range when I get started on Sunday do I still add the borax and muratic acid? Or do I just do the bleach? Am I trying to lower the CYA at all?
    I will purchase the borax and muratic acid as needed I am just not sure why I am doing that.
    40K gal vinyl FOXX pool; Intellichlor IC60 SWCG; Hayward EcoStar multi speed pump that runs 2925 rpm 8am to 1pm, then 2900 rpm 4pm to 8pm then 2800rpm from 8pm to 11pm.; Hayward Swimclear cartridge filter; Pentair Easy Touch panel with remote.
    BigDave's Avatar
    The Borax + Muriatic Acid is intended to establish an effective Borate level in the poolwater. Borates at 50 ppm or so are effective at supressing algae. Borax contributes the Borates. Borax raises pH. The Muriatic is added to compensate for the pH rise caused by the Borax.
    Yes.
    Cleaning-your-Cartridge-Filter-wiithout-Damaging-It!
    Yes.
    I still don't understand the muriatic acid instructions
    Read the muriatic acid page that is linked in my signature. You only need to add acid to (a) lower pH, (b) lower alkalinity, or (c) adjust for borax additions. If your pH & alk is OK, and you don't want to add borax, you don't need acid.
    It's up to you. You have two choices:
    -1. You lower your CYA, and operate with 'normal' chlorine levels.
    -2. You don't lower your CYA, and instead operate with Best Guess adjusted levels.
    I'd recommend #2, but you can't really do that till you have the K2006
