Results 1 to 3 of 3
Thread: Spas
    Jun 2013
    Nebraska
    Default Spas
    I was wondering if you could tell me If Its a good idea to buy a fiberglass pool with a Spa built In or Is it better to buy a free standing spa? Thanks Voosch
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Spas
    Personal preference.The main concern would be if there was a way to isolate the spa to heat it and then make it into one large body of water for maintenace and chems. Also, with separates it is possible to have the spa elevated and allow it to spill into the pool normally and by switching valves isolate the spa. Also, you can probably fit a larger pool and spill over spa into the same space as the all in ones so that is a consideration. Price on the all in ones might be a bit less.
    Default Re: Spas
    membership updated.
  1. New to Pools/Spas
    By twizted1 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-28-2012, 03:51 PM
  2. Question about overflo pool spas
    By hancop in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2006, 09:11 AM
  3. Does the 3Bs work for SPAS?
    By SFspa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-09-2006, 12:35 PM
