Re: Newbie with solar panel question/problem
21 psi seems like a high delta to me. Most solar panels should add < 10 psi to the normal PSI. What was the delta after they were put in?
Since the solar is post filter, it seems unlikely to have anything that would block all or most of the panels at once. It could be the valve but I don't see how that could fail in only the solar direction.
