Thread: How to test CYA
    Default How to test CYA
    I have one of the 4 way test kits from Walmart. There is no mention of how to do a CYA test. Do I need a seperate test kit or need to go with a more expensive one.
    Bob
    faithfulfrank is offline ** No working email address ** faithfulfrank 0
    western New York & Leesburg, Fl.
    Default Re: How to test CYA
    Bob,
    I'm not sure if the 4 way testkit DOES test CYA. I know that walmart does sell a kit that does, but I thought it was a 5 way.
    I'm sure that someone here will know. Next time I'm there, I'll look.
    What does it say it tests? For CYA, it should come with a separate tube with a black dot on the bottom, with a graduated scale on the side for ppm.
    Frank D.
    Morris, IL
    Quote Originally Posted by faithfulfrank
    Bob,
    Frank D.
    I have the five way kit from walmart and it does the CYA test, it is the larger kit, and I doubt that you have it if it is only the four way one.
    IL.
    Our Walmart only sells strips...
    Morris, IL
    I got mine last year, I have not looked there this year to see, maybe they discontinued them? Typical of WalMart, whenever I need something, they are guaranteed not to have it. I am going to need more of the chemical for testing the CYA and I guarantee they don't have it. LOL
    Rehoboth, MA
    The WalMart in my area sells an HTH 5-way test that includes a test for CYA. If your test kit doesn't mention it then it doesn't test for it.
    By the way the calcium test in the HTH kit didn't work correctly on my water. I got Ben's kit from poolsolutions.com and the test in that kit worked fine. Ben's kit also tests for free and combined chlorine where the HTH test only tests for total chlorine.
    Peter
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
