Thread: Stabilizer help please......
    May 2012
    SW Georgia
    Default Stabilizer help please......
    I had my pool water tested today and the CYA was low (20) so they told me to add some stabilizer through the skimmer which I have just done - I read the instructions on the container and it said to add through the skimmer or directly in the pool and then brush. I am worried I may have added it too fast - it just seems to be sitting there and the skimmers dont look like they are working (no swirling water) will this cause me problems? If so what can I do to rectify it. It didnt say to add it slowly and the guy in the store didn't tell me but I am just reading on internet that you are supposed to add slowly. It was 4lbs of stabilizer.
    Thank you in anticipation
    May 2013
    Southeast Kansas
    Default Re: Stabilizer help please......
    Can you reach in there and either swirl it around or dig it out? If you can get it out, put in an old sock and suspend it in front of the return.
    Just swish it around an let it go into the filter. It can take up to week to dissolve so don't clean/backwash your filter or bother testing the level for about a week.
    May 2012
    SW Georgia
    Thanks very much for the replies, I was worried incase I did some damage to the pool equipment.
    Everything is ok today, I managed to swirl it around and the skimmer is working fine now.
    Will certainly remember for next time!
    in-ground gunite pool 20x40; Sta-Rite Dura Glas pump; sand filter
    Jul 2012
    Mexico, Missouri
    A pool store did the testing, right? Or do you have your own test kit?
    Pool stores are notorious for getting the CYA test wrong.
    I will wager that if you were to take a sample of the same water before you added the CYA to that same store, you would get a much different result.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  5. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
