Thread: Intex 10' easy set pool cover fit
    Jun 2013
    Near sunny Buffalo NY
    Default Intex 10' easy set pool cover fit
    I have set up my little pool today and put the cover on it. The cover sags down to the water and I wonder if this is normal. All the pictures I have seen of the Intex pool covers show it stretched across the top of the pool. I see I cannot attach images so I will try to get a picture in here.
    Jul 2012
    Mexico, Missouri
    Default Re: Intex 10' easy set pool cover fit
    You know, when marketing wants images to sell a product, they will fake whatever they have to.
    Whet you have there, is normal for any pool cover that I have seen. I seriously doubt that you would ever get it stretched as tight as the box photo shows, without breaking something.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    Cool. Thanks Charlie..
    Jun 2013
    I cut a piece of solar blanket for my little easy set yesterday. I find it helps a great deal in putting on and taking off the debris cover because it keeps the debris cover off the water. Plus it will heat the water a little.
  1. Hayward Sand Filter for Intex Easy Set Pool
    By Rubber Duck in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2012, 05:27 PM
  2. Base for an Intex Easy Setup Pool
    By Wisewr in forum Intex-type Pool Setup & Operations
    Last Post: 06-01-2012, 06:28 PM
  3. Base for an Intex Easy Setup Pool
    Last Post: 05-20-2012, 07:24 PM
  4. Easy Set Intex Pool
    By Naunnie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2011, 06:04 PM
  5. Intex Easy-Set - Under-Pool mud and MAJOR FUNK!
    By Snowymoon in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2006, 02:45 PM
