The book that came with the K-2006 is pretty useless - completely useless when it comes to chlorine targets. Take your chemistry advice here.
10-4 and how do I get my size of pool filter etc etc at the end of a question? Thanks, Dave Gale
Dansdad,
I think you are talking about making a signature that shows up at the bottom of each of your posts? Go to settings (near the upper right where you log in). Then, on the left side, click create signature. I think that is how you do it. Haven't done it in awhile. Give it a try and lets see if that works.
just did that Watermom thank you
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
I see it! Thanks for doing it. It makes it a lot easier on all of us to help when we can see your pool's specs at the bottom of the post instead of us having to hunt for it.
Edit your signature and add to it that you have a K-2006. That is helpful for us to know as well.
Thanks!
