At 30-50 CYA the min recommended FC is 3 PPM. I don't have Ben's test kit (yet). I'm lookinfg through the test kits I have (OTO... is this a FC or TC measurement?) and 3 PPM is the max the kit'll measure (recommended is 1.0~1.5) Does Ben's kit measure beyond 3 PPMs?Originally Posted by duraleigh
I do have to say I'm a bit nervous... I've had iron staining problems and with high FC, I'm afraid that the iron will be forced out of the water onto the liner. Man I have to get that iron out of the pool!
I guess the danger in running lower stabilizer levels is that the FC will "burn off" quicker on hotter days.
and the FAS-DPD test will be able to test levels up to, I believe 50 ppm free and combined chlorine with an accuracy of either .2 or .5 ppm and would be your weekly test or your test when there are problems.
