Thread: 15 year old liner is failing
    Jun 2013
    Missouri
    Unhappy 15 year old liner is failing
    I need help! My liner is 15+ years old. It started falling away from the walls. I tried to do a temporary fix to survive this year and save money for a new liner but its not working. :-( My pool is a 21x36 in ground . My question is what do I need to do to preserve my pool so it isn't completely ruined? I know I am going to have to put the cover back on and start over next spring. So do I need to drain? Cover exposed wall with tarp? Any help would be greatly appreciated.
    Thankd
    Default Re: 15 year old liner is failing
    Fix it ASAP. Liner pools do not do well without liners or water. If you can borrow money and fix it this fall (a little cheaper than mid-summer), do so. The cost is likely to go up as the pool sits and deteriorates.
    I'll see if Ted (Waste) has further thoughts to add.
  1. Failing liner
    By Fiveattripp in forum --cleanup--
    Last Post: 07-02-2013, 11:07 PM
  2. Three year old pool getting lumps under the liner.
    By Gfresh in forum In-Ground Pool Construction and Repair
    Last Post: 07-01-2012, 04:50 PM
  3. Sagging 8 year old AG pool liner
    By neil999 in forum In-Ground Pool Construction and Repair
    Last Post: 04-12-2011, 12:52 PM
  4. Gettting a new liner this year, couple questions
    By poolmom06 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-14-2007, 03:30 AM
  5. 1 year old liner faded in deep end
    By topnotch in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-06-2007, 07:20 PM
