Results 1 to 10 of 12
Thread: How much chlorine loss is normal?
    Aug 2012
    Gilbert, AZ
    Default Re: How much chlorine loss is normal?
    Ok, here's a little update.
    On 6/26 my FC was 9ppm at 8am so I added 2 gallons of 8.25% bleach, I tested again at 10pm and it was down to 11ppm so I added another gallon. Then today I tested at 730pm and have FC at 10ppm.
    So, as it looks I'm going through about 2 gallons a day to keep it above 8ppm due to my CYA being over 100. Water is still crystal clear so I'm assuming all this CL loss is due to the wonderful heat of AZ.
    PebbleTec | 25k Gallons | Purex Triton Whisperflo pump | Magnetek Century Centurion 1.5HP | Hayward Pro Series S311SX Sand Filter | Taylor K-2006 kit
    posguy is offline Registered+ Thread Analyst posguy 0
    Bayshore Area.NJ
    Ouch, $3 a day in chlorine + $ electricity for the pump. But in that heat I guess its worth it.
    Aug 2012
    Gilbert, AZ
    Yeah, if it weren't for the pool we really wouldn't spend much time outside during the summer. The pump runs overnight when the electricity is cheaper so it's not all that bad...what really makes the electricity bills out here so much is running the AC. I just went through 4 cases of bleach from Sams in a week!
    I was wondering how much the temperature of the water plays a part in how fast my chlorine is being used. Currently my water is at 92, should I consider trying to cool off the water?
