Thread: Compatibility of Walmart 6-way and Taylor R-0013
    Jun 2013
    Massachusetts
    Default Compatibility of Walmart 6-way and Taylor R-0013
    Hi all been lurking for a while just finaly joined. My questioin is will the Taylor Cyanuric Acid 2 oz R-0013-C be compatible with my 6-way hth kit from wally? i off course need more since i only got the 2 test for cya out of it. Cant afford a taylor kit just yet, but i think i will be asking santa for one for xmas so i'll have it for next season.
    tia
    Chris
    BigDave's Avatar
    Default Re: Reagent question
    It should work. I believe the Wall Mart HTH 6way test is put together with Taylor components.
    Jun 2013
    Massachusetts
    Awesome, thank you.
    Jun 2013
    Massachusetts
    Yes i did get it at walmart, and it stinks they give you plenty of all the other tests but so little of the cya.
    The problem they have is with the bulk of the needed R-0013. In the last version of the PS23x testkit I sold, I included a *separate* 8oz refill bottle of R0013, because there just wasn't room to get it into the kit.
  1. R-0013 = Distilled water?
    By Manslick in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2013, 06:34 AM
  2. compatibility of salt systems and stainless steel gutters and bull nose?
    By maintman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 12-27-2011, 04:13 PM
  3. Question about CYA reagent R-0013
    By Yeggim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2011, 06:54 AM
  4. BBB method--from the WalMart guy!
    By aylad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2009, 12:27 PM
  5. ? regarding the Walmart/Aquachem 6 way
    By jnorris in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-18-2006, 09:52 PM
