Results 11 to 15 of 15
Thread: x10 for valve controls
    Dec 2005
    Default
    Hey, MarkC!
    I did look at that, and it seems interesting - what made me nervous is that it does not seem like I would have much control over it - it has built-in functions that you are limited to, from what I could see (couldn't find very good docs on it, though.) Do you have any more info on it, by chance?
    Personally, I came across so many threads in research for this that I can't believe that someone doesn't make something pre-configured to do what I am after. I did get a solution, but I would have liked something more plug-n-play.
    Thanks for the help!
    Quote Originally Posted by MarkC
    http://www.homecontrols.com/cgi-bin/...Spa-Controller
    has an X10 pool controller that with do the 24 volt switching for you. This thing looks like it does quite a bit and it is only a little over $100
    Default Sorry Ben
    Hey Ben, Sorry if I hit a nerve. I was just answering a question with some info. that I had found on the web regarding X10 controllers. I am in agreement with you regarding simple pool controls. I only use an X10 control to turn on my pool light from inside the house. All my other functions are the mechanical timer devices. My pool is pretty simple no spa. I also go low tech to dose my chlorine either with a floater when my stabilizer levels are low enough or manually.
    Sacramento, CA, USA.
    Default
    Try the compool LX120/2T valve controller. It sounds like just what you are looking for.
  1. next step on my basic controls
    By vinper in forum Pool Electronics
    Last Post: 08-18-2013, 08:57 AM
  2. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  3. Jandy valve ... water getting past closed valve
    By Longgrove in forum Pool Equipment & Operations
    Last Post: 06-13-2011, 02:59 PM
  4. PIC How do I get this off/out? Valve
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 09-01-2007, 10:54 PM
  5. Bad Valve or Check Valve?
    By ohpoolboy in forum Pool Equipment & Operations
    Last Post: 08-22-2006, 12:09 AM
