Thread: How full is full on an easy set pool?
    Jun 2013
    Near sunny Buffalo NY
    Default How full is full on an easy set pool?
    I know the instructions for the easy set pool say to fill it up to the ring. Today while I loafed in my little pool I noticed that the sun shining through the ring showed the seam where the ring was attached to the side was a couple inches above the water level. How high do you folks fill your easy set pools? Just to the bottom of the ring?
    BigDave's Avatar
    Default Re: How full is full on an easy set pool?
    A little under filled seems to be OK - the extra wall just sits on top if the water. I would not fill it so much that the water's above the seam.
    Jun 2013
    We had some heavy downpours today so it should be getting close to the seam. I'll keep an eye on it.
    Jul 2012
    Kansas
    from our experience when we had a small easy set, the fuller it was, the more likely the walls would collapse letting tons of water out when the kids climbed in and out over the wall. Some of the easy set style pools have a printed mark in one area inside of the pool showing you what your water level should be... the one we had actually had the mark 3-4" below the seam of the air ring.
    16' round 5K gal Intex AG vinyl pool; 8.25% bleach; Unicel & Filbur cartridges; Intex Krystal 635T pump; 8hrs; Taylor K2006; utility & well water; summer: none; winter: take down; android phone; PF:24
    Jun 2013
    Quote Originally Posted by 7sanders View Post
    This sounds like an easy way to lower the pool level to a kid usable level.
    BigDave's Avatar
    The trouble is that the water coming over the donut can hold it down - pretty much until the pool is empty.
    Jun 2013
    Ah ha. Good point.
  1. I have a pool full of kids!!!
    By aylad in forum General Interest
    Last Post: 05-29-2012, 11:03 PM
  2. Cholrinator full of pucks, but no chlorine in pool
    By timmie in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-13-2008, 06:26 PM
  3. pool almost full....as expected bad numbers
    By induce in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2007, 11:29 PM
  4. Added DE to sand filter. Now pool is full of DE.
    By les_smith in forum Pool Equipment & Operations
    Last Post: 08-17-2006, 08:16 PM
  5. Pool only 1/2 full
    By newtopools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-12-2006, 03:49 PM
