A little under filled seems to be OK - the extra wall just sits on top if the water. I would not fill it so much that the water's above the seam.
We had some heavy downpours today so it should be getting close to the seam. I'll keep an eye on it.
from our experience when we had a small easy set, the fuller it was, the more likely the walls would collapse letting tons of water out when the kids climbed in and out over the wall. Some of the easy set style pools have a printed mark in one area inside of the pool showing you what your water level should be... the one we had actually had the mark 3-4" below the seam of the air ring.
16' round 5K gal Intex AG vinyl pool; 8.25% bleach; Unicel & Filbur cartridges; Intex Krystal 635T pump; 8hrs; Taylor K2006; utility & well water; summer: none; winter: take down; android phone; PF:24
The trouble is that the water coming over the donut can hold it down - pretty much until the pool is empty.
Ah ha. Good point.
