Results 1 to 10 of 10
Thread: Pool Deck Questions?
    Dec 2005
    ny.
    Default Re: Pool Deck Questions?
    Would love to see some pics...
    Whitehall, PA., U.S.A..
    Nice deck hrsdennis, I put one up 2 years ago and it looks very similar.
    As for over, under, or flush with rails, I built mine over the rails but left about 2 inches clearance between. I have a stainless ladder that bolts to the deck. It has worked great for me in PA.
    However it is a real pain trying to cover the pool at the end of the season.
    Imho it's a matter of preferance but do consider what you will have to go through later to cover and uncover the pool.
    Hope this helps.
    Michigan
    Lowes has a pretty decent deck designer software.
    http://www.lowes.com/lowes/lkn?actio...es_splash.html
    posguy is offline Registered+ Thread Analyst posguy 0
    Bayshore Area.NJ
    I used the plan from deckplans.com to go 2/3 around the pool and went about 3/4" under the top raIls. I would think if you have frost heave, the pool wall and deck should move the same, but if not, I dont think the deck would rise more than 1/2" or so. Im glad I went under the rail because now I must remove the top rails to do a repair. Also, I would only use the deck blocks if you have difficult soil to dig in or are not getting a permit. You can get away with a lot less blocks with beams.
    Good Luck
    Anthony
