Results 1 to 10 of 10
Thread: Green Water - mustard algae
    Jun 2013
    Las Vegas
    Default Green Water - mustard algae
    Hi Guys,
    good to be here, and I read a lot already. Here's my current dilemma:
    Water kept turning green, with greenish / yellowish algae clinging to the walls. The wife kept dumping trichlor powder, which didn't seem to do much, so I started reading up on stuff here. Got a CYA test strip (all they had at the pool store), and CYA was through the roof.
    1. Emptied 90% of the pool water (loaner pump had to go back at this point)
    2. Refilled with tap water
    3. Tried to balance with bleach, but water turned green pretty quickly
    4. It's pretty hot here (daytime 115 degrees this week), so that doesn't help
    Got my Taylor K-2006 yesterday, and tested:
    FC 17
    CC 1
    pH 7.8
    TA 160
    CH 140
    CYA 70
    Added 1/2 gal acid last night, and checked this morning:
    FC 10
    CC 0
    pH 7.2
    TA 140
    CH 125 (used the 25 parts per drop this time)
    The pool is still green. I can still see the floor at the deep end (6 feet). Water circulates through the pool cleaner - pump - filter - spa - overflows back into pool.
    I've used some leftover trichlor powder and then regular bleach.
    My question: Do I need to hit it harder / for a longer time with bleach ? Should the pool clear up if the algea is truly dead, or does green mean there is still algea alive ?
    Jun 2013
    Las Vegas
    Default Re: Green Water
    Water is still green, adding 1-2 gallons of bleach per day to keep FC up, and keeping pH in check.
    I know CC shouldn't be my main concern, but it's a plaster pool, and I had recently some tiles fall off. I read some posts that contend that CH doesn't really matter, but I wonder if it's related. There is no harm in trying to bring up CH at this time, right ?
    Also just noticed that I wrote CC in my first post twice. The 140 / 125 number obviously is CH, not CC. Tested CH again today with the 10 ppm / drop, and came to 140 again.
    Jun 2013
    Las Vegas
    Thanks !
    Water is clearer, but is still a little greenish. Algae on the walls, although less (brushing several times a day).
    Last night:
    FC 17
    This morning:
    FC 13
    (all other readings stable)
    I hit it with another gallon of 8.6% bleach, so it should get me well above 20. I'll keep checking throughout the day.
    My understanding is to keep it a shock level until the overnight FC loss is negligible ?
    Any thoughts on the calcium hardness ? Two pool stores I went to didn't have any calcium chloride, so I ordered some Driveway Heat online; should get here next week. Lost 20 tiles around the spa overflow so far, and the grout all around the waterline doesn't look so good.
    I would just use bleach for now and once the water is cleared up, then you can worry about CH.
    You want to keep at shock level (per Best Guess Chlorine Chart in my signature) until three conditions are met:
    1. You lose no more than 1ppm of chlorine overnight
    2. You have no more than 0.5 CC
    3. Your water is clear
    At that point, we recommend keeping the chlorine high for one additional day. Then, you can let it drift down and keep it in range between the min and max listed in the chart. Run your pump 24/7 while you are trying to clear this up. What kind of filter do you have, by the way?
    One last thing. Don't trust pH readings taken while the chlorine is higher than 15. (If you didn't have a Taylor K2006, I would say don't trust pH readings when the chlorine was over 5.)
    Jun 2013
    Las Vegas
    Thanks, I'll try and keep the chlorine up for a while. I have a cartridge filter with 4 cartridges, cleaned it yesterday. I just got a K2006 this week, so that's where I got my numbers. The pool stores around here don't have any decent test kits (but that's normal I guess).
