Thread: Skimmer
    GreenWater is offline ** No working email address ** GreenWater 0
    Default Skimmer
    The skimmer has two plugs..could someone please tell me what each plug is for?
    Thanks! Do I unplug one or both?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Skimmer
    If you mean the outlets in the bottom of the skimmer, one usually goes to the main drain and the other back to the pad. If they both have plugs, then you probably need to remove both.
    Mark
