Thread: Skimmer
    GreenWater is offline ** No working email address ** GreenWater 0
    Default Skimmer
    The skimmer has two plugs..could someone please tell me what each plug is for?
    Thanks! Do I unplug one or both?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Skimmer
    If you mean the outlets in the bottom of the skimmer, one usually goes to the main drain and the other back to the pad. If they both have plugs, then you probably need to remove both.
    Mark
  1. Skimmer
    By 2butterbeans in forum Above-Ground Pool Construction & Repair
    Last Post: 07-07-2012, 05:08 PM
  2. Skimmer Help
    By braeghan in forum In-Ground Pool Construction and Repair
    Last Post: 03-28-2012, 07:32 AM
  3. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  4. CYA Only in skimmer?
    By posguy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2011, 02:05 PM
  5. Skimmer
    By RENOPOOL in forum Pool Equipment & Operations
    Last Post: 06-15-2006, 05:18 PM
