Thread: please help
    Red face please help
    Okay
    14,400 gal above ground pool
    chlorine is 2
    Ph is 7.3 or 7.4
    Alk is in between 40-50
    cya is still 0
    using a 5 way drop test kit
    added about 6 oz of baking soda to raise the alk tonight
    pool has a green tint to it but I can see the bottom very good.
    some places on the liner have brown goop or ring especially the floating chlorinator.
    I have one 3 inch puck of cal hypo in the floater.
    Oh yeah, on Sunday the boys put in yellow out and Monday they put a cup of algae stop because they don't think I know what I am doing.
    filtering 24/7
    Any one have any ideas???
    thank you
    Nicole
    Default Re: please help
    You need to raise your chlorine up to 10ppm and try and hold it there without letting it yo-yo up and down. Test 2 or 3x a day and each time, add enough plain, unscented 6% bleach to raise your cl to 10ppm. In a pool this size, each quart will raise it by 1ppm. Don't add any more stuff other than bleach for now. If you will do this consistently for a few days and keep running your pump 24/7, it will clear. After it clears, then you'll need to add some cya. We can help you with that in a few days.
