You need to raise your chlorine up to 10ppm and try and hold it there without letting it yo-yo up and down. Test 2 or 3x a day and each time, add enough plain, unscented 6% bleach to raise your cl to 10ppm. In a pool this size, each quart will raise it by 1ppm. Don't add any more stuff other than bleach for now. If you will do this consistently for a few days and keep running your pump 24/7, it will clear. After it clears, then you'll need to add some cya. We can help you with that in a few days.
