Thread: 1 HP vs 1 1/2 HP
    May 2013
    Goodyear, AZ
    Default Re: 1 HP vs 1 1/2 HP
    12,500 gallons
    More important, is the pump you are replacing uprated or full rated and ditto for the replacement pump. A full rate 1 hp Whisperflo is exactly the same pump as a 1.5 HP uprated whisperflo (which is often priced less than the full rated 1 HP. Both have a brake HP of 1.65! If you are replacing a full rated pump and you can get an uprated 1.5 hp for the same price do it. If the original is uprated then it is equivalent to a 3/4 HP full rated pump.
