Some of that advice doesn't apply to you -- you have an indoor pool, which is a different beast.
Do NOT use bromide -- on an indoor pool, you have to drain and refill to get rid of it! Not good!
Instead, do this:
1. Immediately, add sufficient bleach to get to an OTO orange-tinted yellow range. (OTO => yellow / red dropper sets) Once you've done so, begin brushing the affected areas daily.
2. Order a K2006 (link in my signature) and test CYA levels as soon as you have it.
3. You can also order polyquat (www.poolsolutions.com/polyquat.html) -- using it will make things easier, and help clarify the water, when you are brushing, etc. It's not essential, but would make things somewhat easier.
4. Consider how old the water in your pool is -- if you swim regularly, and have not drained and refilled in several years, this may be a good opportunity to do so. 'Old' water is harder to deal with -- especially on indoor pools -- than 'new' water. Various chemical residue -- mostly from YOU and other swimmers -- builds up in the water.
5. Understand that biofilms like you have now exist in areas where you see them and can brush them, but also in areas where you can not. Eradication takes long term consistent pool care.
6. Once you decide whether to keep your pool water or not, consider adding borax (mentioned in the post you quoted). Borax will not solve the problem, but it will make it easier to solve, and lasts till the next time you drain and refill.
7. But, IMMEDIATELY get a couple of boxes of borax, and add them slowly via the skimmer, till your pH is in the 7.2 - 7.6 range. 1/2 box doses should be a reasonable step.
Good luck.
