Thread: Replace Pump
    Apr 2012
    Massachusetts
    Default Replace Pump
    My Hayward Super Pump 1hp is, like others here, running extremely hot (can't touch it) and is now also running loud. It is 11 years old. I am second owner and original pump was also replaced at the 11 yr mark. Do I need to replace the whole pump or just the motor? Also, do I need to stay at 1 HP? I do not have a main drain. Just the skimmer and 2 returns.
    Also, should I order online?
    Thanks.
    18x36 Inground, Vinyl Liner, Sand Flilter 22,000 gallons
    mas985's Avatar
    Pleasanton, CA
    Default Re: Replace Pump
    As long as the wet end is in good shape, your best bet is to replace the motor with a two speed motor so you can run it on low speed most of the time and save on energy costs.
    http://www.inyopools.com/Products/00200017003498.htm
    Don't forget that you need a seal kit too.
    http://www.inyopools.com/Products/00500022000632.htm
    Mark
  1. Pump Motor: Repair or Replace?
    By CarlD in forum Pool Equipment & Operations
    Last Post: 05-14-2013, 07:50 PM
  2. Replace old inefficient pump with new more efficient pump
    By TonyG in forum In-Ground Pool Construction and Repair
    Last Post: 03-28-2012, 04:59 PM
  3. Replace complete pump or just motor?
    By AndyT86 in forum In-Ground Pool Construction and Repair
    Last Post: 04-30-2008, 09:12 AM
  4. What do I replace along with the pump motor?
    By deanbrew in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 12:18 PM
  5. Need to replace pump
    By sasgharian in forum Pool Equipment & Operations
    Last Post: 04-10-2006, 08:58 PM
