Thread: Bleach vs Tri-chlor pucks
    Lafayette, La
    Default Bleach vs Tri-chlor pucks
    I have been battling an elevated CYA statrted at above 160 and presently got it down to 100 with partial emptying and refilling (fiberglas pool). After spending hours reading this site I have decided never to use pucks agina and switch to liquid bleach. I have now been told that using liquid bleach causes an increase in TDS which will require me to empty my pool and refill it. Is this true?
    My husband came home this evening and is thinking about switching to a SWG. Any suggestions? 12000 gallon fibergals pool in Louisiana- so I have a big chlorine demand. Thanks for any help or suggestions-
    Caledon, Ontario, Canada.
    Default Re: Bleach vs Tri-chlor pucks
    It might have a minute effect on TDS but I think it would be hard to measure.
    Bleach or pool store liquid chlorine ( which is only bleach at double the strength of bleach) are about the only things that you can put in a pool that will not add anything but chlorine. Of course chlorine gas and SWG that create chlorine will not do that but you must first dump in a lot of salt. That adds a bunch of TDS.
    All the pucks, tabs, sticks, powders and granules and more than just chlorine.
    It seems that most folks that get good SWG systems like them, but you don't get off scott free. They continuously change the PH so you still need to test for that and adjust it.
    My TDS Rant!
    TDS is a bogus test for the most part. IF TDS caused problems then every pool with a SWG would be in big trouble because the TDS is going to be the salt concentration PLUS whatever else is dissovled in the water. TDS is usually given a bad rap in pools with old water that has been using stabilized chlorine and hare having problems. These pools will also have very high CYA levels. The 'cure' for high TDS is to drain and refill. This also lowers the CYA levels. Which is the culprit? TDS? I think not! High CYA levels are KNOWN to cause all the problems that some manufacturers of stabilized chlorine attribute to high TDS such as algae outbreaks and pitting plaster. One company that shall remain nameless is even including copper in their trichlor to help combat the algae that will take over when the CYA levels get too high for the amount of chlorine in the water.
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Quote Originally Posted by grangerhj
    Welcome fellow Louisianian! I am glad you are asking here before you proceed because you were certainly misinformed with the TDS statement.
    Check this link
    http://www.poolforum.com/pf2/showthr...ssolved+solids
    a few highly respected long time members post about the nonsense of the TDS statements. There is also another link provided in the thread if you want to learn more about TDS.
    Have fun and start enjoying the money you save by staying out of the pool store
    Lafayette, La
    Thank you so much for the info- I have enjoyed reading all of your posts. They are always filled with good info. Someone should publish a book with all of these tidbits of info in it. I certainly would buy it! I am not a new pool owner- we have had this pool for 7 years- we only started having problems about a year ago a stuborn algae problem and trouble getting our readings tohold steady-I blamed a lot of things for this porblem and I listened to our pool store and I think we have made the problem much worse. I am still going to research SWG and if you know of any that you like more than others I would appreciate the info- Again thanks for all you knowledge- I am going to use bleach!
    Sanford, FL
    Check out the posts on the SWG forum - there have been a lot of discussions about them and the different manufacturers.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Poughquag, New York, USA.
    I have an Aquarite SWG and love it for making life easy. Don't forget the side benefits (that most SWG users feel) of the softness and better feel of a salt water pool.
    I still use bleach for shocking when I need to (opening plus cases where I screwed up and the SWG "fell way behind" - my timer presets got screwed up and the filter/SWG didn't turn on at night after a heavy use day). The combo works great to balance convience (SWG) against control/quick results (bleach). I prefer the SWG but love the option of bleach when I need it. Best of both worlds.
    Controlling PH has not been much of an issue for me. There is a thread about that now, one of the senior forum users is very chemically astute and is trying to figure out why SWG in vinyl doesn't seem to have the PH issues that SWG in gunite does (not sure how fiberglass fares). In fact, I have had to raise my PH slightly (using Borax), not lower it (yet).
