Results 1 to 10 of 13
Thread: pool green - chemical imbalance?
    Default Re: pool green - chemical imbalance?
    OK, I'll start:
    1) stop using everything you are using.
    2) You MUST get your pH up above 6.9 immediately--use ordinary 20 Mule team Borax to do that. You'll probably need 3 or 4 boxes--just a guess.
    3) You need lots and lots of bleach. I am ball-parking it but I think you'll need 6 to 10 gallons at a time.
    4) Patience, persistance.
    east texas
    thank you so much CarlD! i left the floater in there so i should pull it out as well huh? i kinda figured i had it in shock with all the mix and too much chemicals and it kinda locked up my chlorine from doing anything so i figured my best bet was to stop it all and start over with bleach and borax. will get right on those tomorrow and update.
    east texas
    okay, the floater is out. i put in 4 jugs of the 1 gallon 46 oz from wal-mart. i also put in on 4 lb box of the borax to start with and have the pump/filter running. i have sprayed the filter clean about every hour. now i tested the water 2 hours later and here are my results:
    TH: 200
    FC: 5
    pH: 7.8
    TA: 80
    CYA: 30-50
    do i just wait and be patient to see if this clears it up or does the FC need to be higher to burn out the algae?
    Take your chlorine up to about 12 and try and hold it there. Test several times a day, the more often the better, and each time add enough bleach to shock it back up there.
    east texas
    YEAH!!!!! What a difference the pool looks this morning. the green is now gone but still cloudy so it is going good. here are my levels this morning:
    TH: 400
    FC: 10+ (off the scale)
    pH: 7.2
    TA: 40
    CYA: 0
    so FC is holding good and held overnight. however, the pH came down somewhat and the TA and no CYA. i just added a 4 lb box of soda to bring up the TA. What do i do about the CYA levels and should i add some more borax to bring back up the pH?
    i think i'll jump in and vaccum now; didn't want to go into that yucky green, lol.
    Indiana.
    Check the chlorine often. With no CYA, the sun will eat it up.
