kahmeal
Sorry it took me a while to reply, been a bit caught up with other things the last few days. I have not yet had a chance to track down the leak, however as far as that handle goes; The position it's in is as far as it will turn in that direction. The other possible positions are 12 o'clock which completely blocks all water to the pump and then 2 o'clock which partially blocks the right pipe the same way the left is now partially blocked. Unfortunately these two pipes are not labeled so I'm not sure where they go.
