Thread: Cloudy water after shock?
    Default Re: Cloudy water after shock?
    No. Many people routinely add their bleach directly to the skimmer including me. Just pour it slowly while the pump is running being careful not to splash it on yourself.
    Jul 2013
    Ottawa, Ontario
    Thank you
    I noticed on the bottom of your reply another thread with this information (perhaps you had added it) in reply to a question about TA levels....
    "Otherwise, it's not a problem, except that your pool will be 'twitchy' with respect to calcium and pH. If you add a shock dose of calcium hypochlorite, you might cloud your pool badly. Likewise, if there's much calcium in your pool, letting the pH go up a bit could result in a very cloudy pool."
    Prior to posting I had been suspecting PH as a potential contibutor to my cloudiness after shocking....my PH does tend to run high 7.6-7.8 due to the maintenance Calcium HypoChlorite capsules that I use (they are ~PH 12) - so I am fairly regularly PH downing my pool. I had noticed that after shocking with HTH Extra Shock that indeed my PH goes fairly high up and then the next day I pH it down but by then the white precipitate is present. Can I PH DOWN just before shocking to stop the bounce and hopefullyy avoid the precipitate?
    Connie
