Re: Switching from Sustain Cal-Hypo to BBB
Thank you!
I have a couple questions about starting BBB. How often do I do the overnight FC loss test?
Also, how exactly should I start the switch? I assume I have to figure out how much chlorine my pool will need a night? My target FC is 3-6 so if I am going to be adding the bleach at night do I add enough to get me to 6 or do I need to add enough to get me higher than that to keep it in range until the next night?
Connecticut, AG 24' round 52" pool, 13,500 gal, Proline 22" sand filter, Proline 1hp pump, vinyl liner, Taylor TF-100 test kit
