Thread: Putting in an Indoor Pool
    Default Re: Putting in an Indoor Pool
    Some basic points that many miss in indoor pools:
    1. You must design the pool so that all elements of the build are EITHER
    ==> kept warm to prevent condensation, OR
    ==> waterproof, corrosion resistant outdoor construction.
    2. Use treated wood and approved fasteners throughout.
    3. Use bathroom grade sheet rock.
    4. Use outdoor wiring techniques. Use outdoor lamps. Do NOT use embedded light fixtures; it's almost impossible to avoid condensation & corrosion if you do.
    5. Place as little wiring in the pool enclosure as possible. Do NOT place electrical breaker panels in the pool enclosure.
    6. Oversize the filter, undersize (or right size) the pump; use a 2-speed motor; run on low 24/7, except when cleaning.
    Jun 2013
    Nebraska
    Thank You Doc Pool for your input on my question about building a indoor pool. It was very helpful.
    Thank You Marin! I appreciate your answer to my question. Thanks Again Viki
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    you do not need top brand dehumidifier you need one sized based on Engineered design & caculations
