Re: Replacement pump suggestions?
I just replaced my Hayward Super Pump with the same, only in a two speed. The new pump is very quiet, especially on low. But I find that it doesn't skim very well on low and sometimes my heater will switch off because of lack of pressure while on low. My pressure on high is 16 and low is only 4-6.
Is this common with two speed pumps?
