Results 1 to 10 of 13
Thread: filter question
    Jul 2013
    muskegon michigan
    Default filter question
    i have a sand filter and i have not had to back wash it since i change the sand 5 years ago. before that i would bw it about 3 times a summer. june july aug. the sand i got is #80 from pool supply.
    Default Re: filter question
    Do you have a specific question about this? Do you watch the pressure on your filter? What kind of filter do you have that only holds 80 lbs. of sand? What size pump do you have and what is the volume of your pool?
    Jul 2013
    muskegon michigan
    yes i do. i would like to know why the #80 grit sand will not filter my pool like the sand i used from the cement company. not 80# of sand number 80 sand. two bags so it may be 80# in there as well.
    the filter is a swimquip model 14962 at 50 psi rating the pump is a stayrite 3/4 hp 110/230 re-connectible pump 1 1/2 in and out pool is 18 ft dia by 4 ft deep i figure 7600 gallons. when i have the sand you get in bags from the cement company used for mixing mortar it filtered the pool and about once a month i would back wash it. i then changed the sand and got it form the pool supply store and i have never had to backwash it since. i use the pre filter socks on the baskets then and now. just wondering if that would seem normal. my pool dets a little use and i run it 2 hours a day for filtering. i have to put in clarifier in the spring and it will last all season, till sept. thanks
    You are only supposed to use pool sand for a pool. Also, you should be running your pump 8-10 hours per day for adequate filtration.
    Quote Originally Posted by corvairbob View Post
    There's a very simple rule that's a fundamental part of the BBB method: don't try to fix, what's not broken!
    Is your water clear? If so, don't mess with your filter.
    HOWEVER, for our sake, feel free. I have no idea how your filter could function that way. So if you do decide to investigate, I'd love to know what you find.
    oh yeah. membership updated.
    Jul 2013
    muskegon michigan
    i have ran the pool for 8 hrs. 12 hrs. and all day and night it makes no difference. like someone said below if it's not broke don't fix it.
    Jul 2013
    muskegon michigan
    thanks for the answers. my pool is clean clear as long as i put in a cap full of clarifier every spring. no problems just asking if anyone else has this with their filters. i don't mind not having to backwash it and add water but i was just wondering why it's like this. i could have gotten the incorrect sand from the pool supply center. it happens. so if no one else has this with their filter then maybe i will just leave it be and enjoy the pool and summer. thanks
    Like I said, if it's not broken, don't fix it.
    If, and when, you do a post-mortem on the filter, I'd be interested in photos of the internals, your set-up and macro-photographs (with a dime for scale) of the sand.
    May 2013
    Northwest Indiana
    I had a pretty serious water issue when I opened this spring (first season as a pool owner)... While cleaning up the pool my filter would gain pressure and I would backwash as is normal. Since I resolved the water issue, my pressure has not increased at all. My pool is clear and all is well. I have backwashed once or twice even though the pressure had not increased just to make sure it was clean. From what I understand there is no harm in backwashing "too much". In other words, you cannot backwash too much. Also I plan to add a small amount of de to my sand filter (search other threads on the forum if you are curious about it) in order to 1) make sure my sand isn't channeling, and 2) enhance the filtration. I have also read about washing the sand with a hose, but I am not planning to tackle that until the end of the season. None of this really answers your question, but it does give you some other areas to explore.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
