Results 1 to 10 of 13
Thread: filter question
    Default Re: filter question
    Quote Originally Posted by Themadczar View Post
    I have backwashed once or twice even though the pressure had not increased just to make sure it was clean. From what I understand there is no harm in backwashing "too much".
    Not actually correct.
    With sand filters, the dirt tends to become part of the filter media. As a result, the filter removes finer and finer particles, as the cycle continues. This is particularly important during algae cleanup.
    On the other hand, sand in filters that are rarely or never cleaned can become 'goo-ey'.
    A better solution, rather than excessive backwashing, is adding your chlorine via the skimmer. This will break down the oils and goo, that may otherwise accumulate. Just be SURE that there is no MIXING of chemicals going on -- do NOT pour bleach into a skimmer that has a chlorine tab in it.
    And particularly, do not dump cal hypo granules in, if you have added stabilizer to the skimmer in the last 3 - 4 days.
    May 2013
    Northwest Indiana
    So are you saying that I should only backwash when the pressure guage is +5 psi even if it's been weeks (or it never happens)?
    Thanks for the clarification though. I learn something every day here!
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Yep. That's what I'm saying.
    If you want to add DE to polish your water, you can probably force a backwash, after the really fine stuff is removed.
