Results 1 to 10 of 13
Thread: filter question
    May 2013
    Northwest Indiana
    Default Re: filter question
    So are you saying that I should only backwash when the pressure guage is +5 psi even if it's been weeks (or it never happens)?
    Thanks for the clarification though. I learn something every day here!
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Yep. That's what I'm saying.
    If you want to add DE to polish your water, you can probably force a backwash, after the really fine stuff is removed.
