Slide H2O recirc question
Not sure if this is the right area for this question - hope so, if not sorry!
We have installed a replacement for our old Aqua Slide n Dive Slide with a new one by SR Smith. The water supply system is so much better than the old one was (significantly wider & tougher tubing, and no T joint to contend with).
Rather than tax our well & pump by running a water line to it from our hose (not to mnetion the temperature issues), I have been trying to figure out a safe way to use water from the pool to lube the slide - some sort of recirculation system.
One of the 2 skimmers and one of the 2 returns are each in close proximity to the slide. I thought if I could figure out a siphon system (ideal as no pumps or electric), use the return line, or use a pool cover pump in the skimmer (less ideal as there is the electricity issue) that I would have the problem sewn up.
Anyone out there have a similar or better solution?
18x42 Spartan Roman End Vinyl Inground (1981)
1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
