Your not all wet, just a little wetOriginally Posted by larry2338
We have a very high water table, and I have a drywell under the deep end of the pool. Further I have burried 6" perf pipe and lots of gravel only about 15' from the pool. Since the lines are most likely about 40" below the ground they all drain into either the water table or dry well. Remember that the Polaris line is about 1" in diameter and is fed from a high pressure booster pump. The actual opening from the orifice to the polaris is about 3/8", so there is a lot of pressure in the line when the pump is running, so if you have a 3/8" crack you would get as much water going into the ground as going into the Polaris.
