Results 1 to 3 of 3
Thread: Low PH
    Jul 2013
    Tennessee
    Default Low PH
    Just trying to get my account started and haven't read all I need to yet.
    I cannot get my PH level up but will research more.
    Default Re: Low PH
    Tell us about your pool and equipment.
    What all have you added to the water? (Ingredients, not product names.)
    Can you give a current set of testing results taken with a drops-based kit?
    Default Re: Low PH
    1. Buy a NEW cheap local OTO / phenol red (yellow / red drops) and test your pool. Teststrips -- especially last year's test strips = "guess-strips". Report what you find.
    2. Regardless, if your pH is below 7.0 (yellow pH drops solution), add 1 box of borax (slowly, via the skimmer, pump ON) every 4 hours. Test and repeat if the pH is still below 7.
    ==> www.walmart.com/ip/20850525
    It's in the detergent section.
    Membership updated.
