Results 11 to 14 of 14
Thread: New variable speed pump loosing prime at low speed
    Jul 2013
    Default Re: New variable speed pump loosing prime at low speed
    So, this morning pump basket was empty again. Last night I watched it for a while, and what I noticed was the bubbles are now gone coming in from the skimmer. Now what I notice is an occasional large bubble coming up from the pump side. This does not make sense to me. Do I need to turn up the speed? Running 850 rpm and about 5 psi.
    Centrifugal pumps can handle more air at high RPM, than at low RPM. Of course, the suction will increase too, possibly causing the leak to increase. But hopefully, there's a higher RPM that will handle air incoming from the leak, without increasing the leak so much that the pump cannot help it.
    One other point to consider - as the leak increases, the SOUNDS from the leak also increase. There are some leak detection tools that exploit this, but they are not cheap:
    http://www.leaktools.com/mm5/merchan...egory_Code=LD2
    You might want to check around and see if someone in your area can perform that sort of leak detection. You may also want to check out these two flow-charts, from that same company:
    http://www.leaktools.com/professiona...ion%20Gath.pdf
    http://www.leaktools.com/professiona...re%20Test2.pdf
    Jul 2013
    I own an ultrasonic leak detector designed to detect ultrasonic gas leaks in refrigerant systems. It also detects vacuum leaks. I will try it out and see what happens.
    Lemme know how that goes. I've never heard of anyone trying that, and I'd be interested to know if it will work.
