Closed Thread
Thread: Returns
    Dec 2005
    Denham Springs, Louisiana, USA.
    Default Returns
    Is it better for circulation if you point your returns up or down? I have an 18 x 36 inground vinyl pool with no main drain, one skimmer and two returns. (I also have a polaris with a booster pump).
    Casey
    mas985's Avatar
    Pleasanton, CA
    Default Re: Returns
    Down helps mix the water better to lower levels but up helps the skimmers so if you have more than one it is best to do both.
    Mark
    Default Re: Returns
    Quote Originally Posted by crosso
    Casey
    I have a 20x40 and keep one up and one down which works great. Do you get adequate circulation with just one skimmer? I ask as mine has a main drain and two skimmers so I am kind of surprised that you get by with only one on a pool that is not that much smaller surface wise.
    Dec 2005
    Default Re: Returns
    Quote Originally Posted by cleancloths
    The pool stays suprisingly clean. I was worried at first when I started reading this forum and a lot of people seem to have more returns and skimmers, but my water stays crystal clear and my chemicals are balanced. So I guess everything is working fine.
Closed Thread
