Green Tint
I have everything in line as far as numbers, testing just done and had 1 fc low but normal for overnight loss 0 cc 7.5 ph 90 ta and 40 cya.
when I add bleach the water turns green, if I let all the chlorine go out the water clears up but adding the 2 quarts to bring the fc up to the 4 tints the water, water pulled from fresh water stream in my front yard so there shouldn't be any metals in it to be an issue.......... any ideas
18x33 15700 Gal Oval Above Ground
Ranger Sand Filter w/Praher Multi Port Valve
A.O. Smith 1.5 hp Pump
Confer E9120 Steps
