Results 1 to 10 of 57
Thread: CYA over 100 with yellow/mustard algae
    Jul 2013
    North Texas
    Default Re: Need a better phosphate remover
    Quote Originally Posted by FormerBromineUser View Post
    I found 9.99 shipping but am out of town now and can't check where I found it. It was 33.90 with shipping and the store had good ratings. I think I used yahoo shopping.
    OK, I finally found the site you are referring to using Google Shopping. Very sketchy. The site has at least 4 or 5 different variants with slightly different content and pricing, which makes me distrustful right from the start. But also, they add $4.50 handling fee at checkout, so the total delivered price is right at ~$40 for one pint. Shipping and handling is almost as much as the product itself.
    Not trying to be cheap here. I just don't trust internet retailers that set up multiple websites with similar content but slightly different pricing. Then advertise a low-ball price to appear competitive on Google Shopping, and pile on bogus charges at checkout. I won't buy from them on principle alone, assuming they even exist. I went to scamadviser.com, and got the following for all the site variants: "The website has been newly registered with a short life expectancy, which follows the pattern used by many fraudulent and fake selling websites. Please be vigilant and take extra care before providing any payment information."
    Here are some of the variants, 4 of which appear in the top 5 on Google Shopping for the Orenda product, but have no seller ratings:
    http://www.poolandspapartsnow.com/
    http://www.allpoolandspaparts.com/
    http://www.poolandspapartsmart.com/
    http://www.poolandspapartstoday.com/
    http://www.poolandspapartssuperstore.com/
    So, I'm still looking for a legitimate source for this Orenda product, or a more cost-effective alternative.
    I keep coming back to the SeaKlear commercial product which has nearly same effectiveness (per the label) as Orenda, but I can get twice as much for my $40, and use Amazon instead of all these sketchy online pool sites.
    __________________________________________________
    35X20 in-ground gunite, free-form, 18k gal, pebbletec plaster, Pentair cartridge filter, Pentair 1.0 HP WhisperFlo pump, Polaris 280, heater, waterfall, Taylor K2006 kit and K1106
    Jul 2013
    North Texas
    OP here with a quick update. I was able to procure a pint of Orenda PR10000 for a reasonable price online, $24 plus $6 shipping. I've been dosing over the last several weeks. In theory, I should have only needed 5.7oz to reduce my 18kgal pool by 1000ppb. After two quarts of the Clorox product, plus 12oz of the PR10000, I'm still at ~300-400ppb phosphates. I just added the last 4oz of the Orenda product to see if I can get a little closer to 125ppb. Either my water was a lot higher than 1000ppb or these products remove far less phosphate than indicated on the label. I've had very minor clouding for about an hour after each dosing, then it clears up by itself. I used no clarifier. The pressure on my cartridge filter has gone up *maybe* 2psi. Anyway, I've been at this since mid July, and still don't have the phosphates down where I want them. I still have the yellow algae although it's less noticable... could be the lower phosphates or the lower water temps. CYA is 37 and I've been keeping FC in the 6-10 range.
    Jul 2013
    North Texas
    Default
    Just another quick update... It's been one week since I added the last 4 oz of PR10000. The phosphates are right at 200 ppb. The effectiveness of this Orenda product is no where close to what's indicated on the label. Anyway, I'm done for this year. The water temps are down in the mid 70s and the yellow algae still returns, but much more slowly than before. After brushing, it takes about 3-4 days to notice the algae (vs 1-2 days previously), and it's a much smaller growth than before... probably some combination of lower phosphates and lower temperatures. FC consumption is steady at 2.5 ppm per day. My cartridge filter pressure is at 19 psi, up from 12 psi after the last cleaning in May, which is maybe 2-3 psi higher than it would normally be, absent any phosphate removal process.
    Virginia
    Default Re: CYA over 100 with yellow/mustard algae
    Thanks for the update.
    That's disappointing that the PR10000 isn't near as effective as advertised. I've been keeping an eye on this thread should I ever decide to lower phosphates.
    Edit: I just noticed I've been upgrade to "Verb Herder". Hmmm...is that a complement or an insult...lol.
    Jul 2013
    Northern Illinois
    I am disappointed too. Congrats on the Verb Herder! You're in the Big Time now, buddy!
    Richard - ChemGeek - uses PR10000 and reports that PR10000 *does* remove PO4 as predicted.
    But . . . what I'm seeing myself (I'm using it) suggests that it only does so AFTER you have lowered PO4 levels fully. What I suspect is that there are more phosphates in the pool system -- pipes, pool surface, filter media -- than there are in the water itself. This would not be surprising, since phosphates are often.added to water in the first place because of their abilities to attach to surfaces. If I'm right, then the attached phosphates will only be released back into the pool water when the PO4 levels begin to get low (< 500 ppb?).
    My guess is that attached phosphates will be low in all plastic pools with cartridge filters (plastic liner, plastic pipes, plastic equipment), but high in concrete or stone pools with sand filters.
    I would strongly encourage you, if you've reached 200 ppb, to go ahead and get that next quart. 200 ppb is NOT low enough to be very helpful, but it's very, very close to 100 ppb, which IS low enough. If you stop now, you are sort of like someone who started a 10k run, but stopped at 9.8k.
    I should add, that I'm seeing a consistent MAJOR improvement in mustard algae control, when PO4 levels are at 150 ppb or less.
    By improvement, I mean that the mustard algae is MUCH slower growing, and MUCH less chlorine resistant.
