Closed Thread
Results 1 to 8 of 8
Thread: slippery steps
    Honesdale PA
    Default Re: slippery steps
    Just a thought but how about strips they sell for bath tubs? Have no idea what it does to vinyl but I suspect, nothing. It may not even stick to vinyl.
    duraleigh Guest
    Hi, folks,
    The bath tub strips work great....they're on the top two steps of my pool. However, Diane was looking for something to apply underwater and they won't stick.
    Diane, I put mine on just the top two steps and it solved my issue....maybe you could drain down to one step at least and try them.
    Ted, are you saying I have algae in MY pool?
    Lightbulb Re: slippery steps
    Quote Originally Posted by duraleigh
    Hi, folks,
    Dave, I can almost garuantee that you have algae in your pool. The difference is that the algae in your pool is dead from a sufficient fc level and will soon be filtered out
    MY experience with pools is a lot different from most of the members here, I don't own one (the condo association won't let me put one in [and I think they're begining to suspect I put in the 2, 1000000 gal storage tanks, under the parking lot, for the water everyone sends me. ]), usually the only reason I see a pool is because it needs to be built or there is a problem. I've never known the joy/ hastle of having my own pool. (I'm going to start a thread in China or Off topic on this) I wanted to make sure that Diane's cl levels were right, as she's a newbie, sometimes the 'simple fix' is the right one and I didn't know a way to give her what she needed.
    However, I've come up with a possible pool solution. Without draining any water, use the bathtub strips (though the fish shaped ones would be more apropriate) but coat the back, glued, side with liner patch glue - (bonus - when applying the patch, or in this case, strips,- use a wallpaper roller to work out any wrinkles or air bubbles, works like magic!). Just my $.02, what do I know? - Ted
Closed Thread
  1. steps
    By airraid1999 in forum Pool Equipment & Operations
    Last Post: 06-01-2011, 08:42 AM
  2. Which steps for AGP??
    By 94ukgrad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2010, 08:41 AM
  3. Clorox Regular bleach is slippery
    By CandyMoss in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-18-2010, 03:37 PM
  4. Need a Solution for Vinyl Slope Slippery in Spots
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2007, 08:36 AM
  5. The new steps are here!
    By NWMNMom in forum Pool Equipment & Operations
    Last Post: 05-08-2007, 12:31 AM
