Thread: New Owner - Old Pool with Algae
    Jul 2013
    Texas
    Default Re: New Owner - Old Pool with Algae
    Add 3 gallons tonight. Test tomorrow PM with OTO. If you get a DARK yellow OTO reading for chlorine, add 1 gallon the following PM. If you get medium to light yellow, add 2 gallons. Clear, add 3 gallons.
    Added some chlorine granules (the last of a bottle we had in the garage) and 3 gallons of bleach last night. Bought the HTH 6-way kit at Walmart and tested this morning:
    TC 10+
    pH ~7.3 (darker than 7.2, lighter than 7.5)
    Alk turned pink at 100 and red at 110
    Total Hardness - did not turn red with the indicator
    CYA 38
    What kind of filter and pump do you have?
    Hayward Pro Series High Rate Sand Filter Model #S244T
    Pentair SuperFlo High Performance Pump
    (I'll add those to my profile.)
    I brushed this morning and, for the first time, I could see the brush on the bottom of the deep end (6 1/2 feet) AND I could see it making white brush lines through the green at the bottom and stirring up clouds of green.
    I backwashed the filter (the site glass was nasty looking!) and rinsed. I have been backwashing and rinsing daily for the last 3 days. The filter has been on 24/7.
    Should I shut the filter off and let the algae settle to the bottom so I can vacuum it? I'm assuming I should vacuum to waste.
    I have an unused bottle of KemTek Ultra Clarifier. It doesn't list ingredients other than "Cationic Particles". Is that something I should use or just return it to Lowes?
    Thanks!!
    1. If the chlorine is high, and the algae appears dead, you can turn the pump off, and see if it will settle. Make sure the chlorine REMAINS high during this process.
    2. If you want to try the clarifier, try to settle it FIRST. Some clarifiers help settling; others don't.
    3. Don't backwash too much -- doing so reduces your ability to remove the dead algae. Let the filter pressure increase to 5 psi ABOVE the clean filter pressure, before backwashing.
    Jul 2013
    Texas
    Can you explain #3? We are new to pool ownership and learning the basics as we go. I've been backwashing based on the advice of a local pool guy I spoke with on the phone who said we should be backwashing once daily until the algae is gone. We have someone else coming out in a couple days to look at our pool and equipment and give us a crash course on owning a pool.
    Also, how would I find out what our clean filter pressure should be? It's been running pretty consistently at 17psi both before and after backwashing. I found and downloaded the manual for our pump but it didn't have much info. Can you recommend any good links or sites for learning more pool basics? Thanks!
    15'x30' IG concrete chlorinated pool, Hayward pro series high rate sand filter, Pentair SuperFlo high performance pump
    On a sand filter, as the cycle progresses, the dirt becomes PART of the filter media, allowing you to filter out finer and finer particles. When you backwash too often, you break this cycle.
    Jul 2013
    Texas
    Thanks for all the great info on this site! For the first time since we moved in a week ago, we have a blue pool! My kids are so excited (and I'm so relieved)!
    I have been treating exclusively with chlorine, keeping the levels up around 10ppm or higher, without much improvement. We visited a local pool supply store and picked up some sodium bromide at the manager's suggestion. (I was going in for Polyquot 60, which he said was good, but he said he's seen much better results with sodium bromide in our area.) I added 4oz of sodium bromide with about a pound of cal hypo last night. The pool was still green this morning and the chlorine levels had dropped to around zero. Because of all the reading I've done on this site, I was expecting that and added a couple more pounds of cal hypo. Four hours later, we have a blue pool! First time since we have been in this house!
    I know the bromide will increase my chlorine demand so I'll monitor that every few hours until the levels start to hold. Our pool is in direct sunlight, so I understand that will help dissipate the bromine in the pool. The pool is still cloudy but I believe that is from both the dead algae and the cal hypo. We will continue to brush and vacuum daily and run the filter 24x7 till the water is clear.
    Thanks for all your great advice and info! (Can someone approve me for the forum?)
