Solution was a little cloudy . Do I need to do something about that? Also on the 6 way test kit for the cl and ph test do you have to let it sit for a while in the test tubes to read or can you read it as soon as you add the drips and mix . Also pool is clear but has a little green shade to it what could that be and how could I get rid of it
