Results 1 to 10 of 38
Thread: Little green on stairs
    May 2013
    Concord,ca
    Default Re: Little green on stairs
    Ok Watermom, I got the titrant and the cya is so bad I can still see the black dot on my 2006. Looks like maybe 25. pool calculator says about 4 cups stabilizer then chlorine. My chlorine is down to 2.3 I have some bags of shock maybe 2 bags, more stabilizer. BTW how would you add stabilizer? I was told use a sock
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    What are the ingredients on the bags of shock?
    May 2013
    Concord,ca
    BTW how long does it take for granular stabilizer to show a difference. I cannot even tell if I have any
    May 2013
    Concord,ca
    calcium hypochlorite 73%
    other ingredients 27%
    minimum 70% available chlorine
    If you think I need another type I will get it
    If your CYA is less than 30, it won't be detected.
    How much total CYA have you added to the pool?
    Have you used any dichlor shock or any trichlor tabs?
    May 2013
    Concord,ca
    Total as of yesterday 4 cups granular stabilizer, have not used dichlor nor trichlor. I have in the past and can get more pronto
    The shock I used before is Trichloro-s-trianzinetrione 67%
    other ingredients 33%
    total100%
    Available Chlorine 60.3%
    as I have a fiberglass pool does it matter which one? or is the Trichloro better?
    May 2013
    Concord,ca
    what about 2 bags ( 20 oz) of triclo and 6 cups of stabilizer. Should that slow down the process and then keep cl at 5
    By weight, do you know how much granular CYA you have added?
