calcium hypochlorite 73%
other ingredients 27%
minimum 70% available chlorine
If you think I need another type I will get it
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
If your CYA is less than 30, it won't be detected.
How much total CYA have you added to the pool?
Have you used any dichlor shock or any trichlor tabs?
Total as of yesterday 4 cups granular stabilizer, have not used dichlor nor trichlor. I have in the past and can get more pronto
The shock I used before is Trichloro-s-trianzinetrione 67%
other ingredients 33%
total100%
Available Chlorine 60.3%
as I have a fiberglass pool does it matter which one? or is the Trichloro better?
what about 2 bags ( 20 oz) of triclo and 6 cups of stabilizer. Should that slow down the process and then keep cl at 5
By weight, do you know how much granular CYA you have added?
I would say at least 16-20 oz. I did it by volume 4 cups last night, but that is approx. 20 oz.
Watermom, its hard to tell weight as my conditioned didn't come in a bag, just a tub. But looking back if I were to put the 4# in bag form it would probably be 3 bags, hence 3 #
