Thanks for all the responses
Janet, Please correct me if I'm wrong.Originally Posted by aylad
I was under the impression that while stabilizer keeps chlorine in the pool, it prevents some of it from doing it's job and therefore more is needed to do the same sanitizing job as lower amounts in a low/no stabilizer pool.
For example, imagine after a party, 3 busboys (FC) start cleaning up. 2 drunken women wander back in (stabilizer) and grab two of the busboys and start dancing. There's still 3 busboys in the room, but only one is doing an work. Manager (pool owner) quickly sends 2 more busboys in to do the work, now there's 5 busboys in the room, but only the 3 are doing any work, the same as was getting done without the drunks.
If this is how it works, why is CYA even needed at all?
In the past before finding this forum, I like others ran a sky high CYA because the pool store wanted it that way. Now I know why...
I used bleach about 1/2 of last season, and closed it with bleach. This spring my CYA is low, about 20ish, and I'm maintaining FC between 3-5 ppm, and so far so good.
) I am trying to find more info on the chemisty of this right now and can only find bits and pieces here and there.
