Thread: hard water
    Jul 2013
    Malibu, CA
    Post hard water
    lots of calcium in pool water - hardness reads over a 1000.
    i am bringing the TA and alkalinity down following your protocol and it seems to be working. i am manually aerating the water and hopefully the hardness will dissipate.
    Default Re: hard water
    Nope. Aerating remove carbonate alkalinity, not calcium hardness.
    The only way to remove hardness, is to precipitate it. And, with CH=1000, that's something to consider. Read this post on removing calcium: http://www.poolforum.com/pf2/showthread.php?16992
    Meanwhile:
    1. Get a K2006. Test kit info page link in my blue signature block.
    2. When you have the kit, test BOTH your pool water AND your fill water.
    3. Report results here.
    PS: Lower your alkalinity will reduce the liklihood of scale formation -- so it's worth something. But it would be better to lower alkalinity AFTER removing calcium.
