Results 1 to 10 of 18
Thread: Green Water - Algae?
    Jun 2012
    Minnesota
    Default Green Water - Algae?
    Hey everyone! Before I tell my story, some numbers. I have the Taylor K-2006 test kit and here are the current numbers (that I think are relevant to my situation):
    FC: 4 ppm
    CC: 0 ppm
    pH: 7.4
    CYA: 45
    My 15' Intex Ready Set pool has suddenly developed green water. For the past few weeks, I've been keeping the FC levels around 8 to 10 ppm using trichlor tabs. Based on the Best Guess Swimming Pool Chlorine chart, I finally decided that was higher than needed and scaled it back about a week ago to the 4 to 6 range.
    About that same time, I noticed that the amount of dirt and junk in the bottom of the pool had dramatically increased. So, I vacuumed (twice). And the water has been green ever since. The junk picked up by the vacuum was mostly a fine sandy grit along with some grass clippings.
    Since I've kept my FC up (testing at least once per day), I wrote the greenness off to me just dispersing some of the dirt into the water. I swapped out the filter and have been running it 24 hours/day. But it's been a couple of days now and the water is still quite green.
    Tonight, I pulled out the filter that I installed yesterday to put in a clean one and noticed that it also is very green. Which got me thinking that I might have algae after all. The filter is one of the little ones that comes with most Intex pools. I use unicel filters, which get swapped out every 4 to 7 days.
    My gut still says it can't be algae but the green filter has me a little spooked. The vinyl walls of the pool do not feel slick or slimy at all.
    Any thoughts or suggestions? I'm thinking about using liquid bleach to shock the pool and see what happens.
    One other thing: I know some of the above conflicts with the information in my signature. That data is out of date but I can't seem to change it; I just get an error message when I try to save the updated text.
    Thanks!
    Donovan
    15' round 4K gal Intex AG vinyl pool; Kem-Tek granulated dichlor; Unicel Type A cartridge filter; Intex Krystal Clear, Model 637R, pump; 12hrs; Taylor K-2600 test kit; utility water; PF:30
    Jun 2012
    Minnesota
    Default Re: Green Water - Algae?
    Hey Watermom! I don't have the container anymore, having put the last tabs in my floater. I do know the container said 99% trichlor with no mention of copper. After the problems I had last summer with daughters skin reactions, I learned to be pretty careful about additives
    Sorry not to be more concrete.
    How have you been keeping the chlorine high with only trichlor tabs?
    Jun 2012
    Minnesota
    About a month.
    + Dose your pool in the evening with bleach to take levels 15 ppm or higher -- 1/2 - 3/4 gallon of bleach should do it.
    + Brush your pool thoroughly the following AM.
    + Continue to dose with bleach in the PM to 15+ ppm, for 3 days after there's no green anywhere. (A gallon of 8.25% bleach will add ~20 ppm to your pool.)
