Thread: Sand filter leaking sand back to pool....
    Jul 2013
    Default Sand filter leaking sand back to pool....
    Repairable or time to replace?
    Default Re: Sand filter leaking sand back to pool....
    -- membership updated.
    On most in-ground pool filters, it's repairable. If it's a small AG filter, you'll need to check and see if you can order parts. The most common failure is in the "laterals".
    Jul 2013
    Thanks for the info PoolDoc! I have an in-ground, good to know that it may be repairable.
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    What Ben said. The laterals are strainers that radiate from the middle of the filter at the bottom. Common for them to get brittle and break. Small break will allow sand to enter the filter outlet.
    Parts are cheap, but it's labor intensive (sand removal).
